CoyoteDuster1970 Well-Known Member Joined Feb 23, 2021 Messages 74 Reaction score 23 Location Mount Carmel, Pennsylvania Feb 25, 2021 #1 Will this pan work on the 5.9 with an LA timing cover? Mancini Racing Center Sump Oil Pan Kit
70aarcuda Master Hoader of SBM Legendary Member Joined Jan 16, 2005 Messages 16,639 Reaction score 5,967 Location las vegas Feb 25, 2021 #2 yes..just make sure you use a LA pan gasket.
CoyoteDuster1970 Well-Known Member Joined Feb 23, 2021 Messages 74 Reaction score 23 Location Mount Carmel, Pennsylvania Feb 25, 2021 #3 70aarcuda said: yes..just make sure you use a LA pan gasket. Click to expand... Thanks I just wanted to be sure I ordered the right pan lol
DionR Well-Known Member Joined May 7, 2008 Messages 4,941 Reaction score 2,429 Location Spokane, WA Feb 26, 2021 #4 70aarcuda said: yes..just make sure you use a LA pan gasket. Click to expand... You can use the Magnum one piece gasket if you account for the gaps at the front corners. I filled mine with RTV and haven’t had an issue in several years.
