TrailBeast
AKA Mopars4us on Youtube
Does an electrical oil pressure gauge need a voltage limiter, e.g. a resistor to limit voltage? Will the gauge and sender both need a live wire to them? Will the length of wire be limited? Will the gauge and sender be matched or be specific to the engine? Will an after market supplier provide this information? I've had not been able to determine these things by viewing catelogues on line.
Thanks, Richard.
No on all counts, except maybe the aftermarket supplier question.
Aftermarket stuff is very generic.
Usually power only goes to the guage, and the sender wire is the ground that varies the voltage to make the guage read different values.
I guess if you used 100 feet of wire it might affect things.
Guages are not engine specific.
