Hi there, after many problems i can finally drive my truck on the street (d100 318v8 new process 435), it pulls hard, im used to drive 2.0 liter 4 cylinder " engines" and wooooow this thing pulls very hard and sounds great too.
Now its time to "tune" the engine and get rid of little problems... I have 2 questions for you guys.
1. Im hearing a little ticking after the engine is warmed up and has been runing for bout 20 minutes, i suposse its a lifter but the funny thing is that i dont hear the tiking at the valve covers but i hear it under the engine, oil pan/clutch area, clutch lower cover is removed and nothing weird seems to be going on there... I know the lifters are pretty low under the heads so it might have sense to hear it tiking down there ( i dont believe its rod knock since the sound goes away with increasing rpm)
.... Is this assumption stupid?
2. When engine is warm it idles at about 30 psi oil pressure but i nottice the needle of my pressure gauge oscillates about 1-2 psi...this ossilation goes away with increasing rpm too ( autometer mechanical gauge i have used it in several 4 cylinder engines with no oscillation). I suppose this small oscillation might be normal in this engine since the oil feed to the conecting rods its not constant (lower main bearing not grooved) so this variation in pressure migh become noticeable at low engine speeds.... Too much assumptions? Is my engine dying??
