plymthmopar71
New Member
just built my 318 not too long ago and i finally got around to finishing it up and when i went to prime the motor for oil, only the passenger side head had oil coming out; driver side is dry as a bone.
specs: 318 bored .040''
shaved heads .020''
roller lifters cam etc..
edlebrock dual plane manifold
closed chamber J heads
motor came out of a mid to late 80s van, had center point injection, i swap over to a carb set up.
etc..
question #1 i have mainly is does it matter which head goes on either side, and if so, what/ where are the markings that indicate so?
question #2 i was told that the magnum manifolds work great for flow and save room and keep a nice stock look to the car, i am not sure though that there is enough room with the stock mounts for them to fit, has any one here ever attempted this on an a body?
Thanks! :blackeye:
shaved heads .020''
etc..
Thanks! :blackeye:
