gzig5
I need to provide a new oil pump driveshaft to my builder because the old one is all scored up. Putting together a 340 with lighter pistons and rods, HV oil pump, etc. Will be spinning it up to 6500 or so and want to use a good part. Not a lot of readily available selection out there at the moment and I need it quickly so the build can proceed. Is the Mancini MRE212153 a good part? Says it it hardened shaft and OK for HV pump. I've heard good things about Mancini but nothing in particular about this part. I think the only other one I've found ready to ship is Milodon and that carries a premium price. I'd get the Hughes Melonized one before dropping that much on a Milodon standard shaft. Any other manufacturers or suppliers I should look at? Been on Summit, Mancini, Jegs (yuck!), and Hughes so far.
