The above post has some significant misconceptions. The below applies to the SBM pumps:
1. The HV pump has the pump capacity to pump ONLY 18-20% more than the stock version for the SBM design. That difference is set by the relative height of the impellers. It is not a big difference. Other types pump designs can have a much greater difference in HV versus standard flows. However pump capacity is NOT actual flow into the engine.
2. The pressure will be limited by the relief spring in either model beyond a certain RPM.
3. In the SBM, the pressure limit of the relief springin conjunction with the clearances in the engine sets the actual flow out of the pump into the engine. So with the same relief spring in both pumps, the flow into the engine WILL BE THE SAME at any RPM where both pumps have reached the relief spring's pressure limit.
4. In the SBM oil pump design, the excess oil bypassed by the relief spring simply reflows around inside the pump, so there is no oil lost there that can help run the pan dry.
5. Due to 2-4 above, you are no more likely to run the sump dry with either pump.
6. For a given set of engine clearances, the HV pressure will be higher ONLY at low RPM's, before the relief spring is not open. This is the ONLY area of engine operation where the HV pump makes any difference vs the standard pump for the SBM pump designs. So the HV pump offers higher pressure at idle and low RPM's, and thus more oil flow into the engine at idle low RPM's. This MIGHT give better wear resistance for a street and cruiser engine. And it will obviously help pressure a bit on larger clearanced engines.
