MileHighDart
So I've only had it out for a few short drives, then to work and back on thursday. All was fine except throttle pressure cable needs further adjustment.
This morning I adjusted my kickdown cable, added a return spring, fixed a small leak on one of the cooler lines.
Go to take it for a drive and trying to back out of the garage, it feels like the brakes are on when i'm in reverse. Give it some gas and she'll start moving, with kind of a chug chug motion, then I let off the gas and she stops like i had my foot on the brake, but I dont. Moves forward fine.
Any ideas ?
p.s. dont know if this is related. Overdrive is working fine, but converter lockup only worked once on my first drive and has not worked since.
Any ideas ?
