ok last trans question for the night - are there different gear arms and linkage rods
jasonmrenda
i think my trans issue is that the linkage rod is not actuating the trans gear selector arm enough. it does the first time through the gears but when i go back up to Park and then down again, the linkage rod is not allowing the trans gear arm to return all the way to Park and thus throws everything off.
i am wondering if perhaps because i am using all the parts from the /6 67 on the 76 tqflite trans, that maybe i have an incorrect ratio between what the trans gear arm is doing and what the length of the linkage rod is doing?
does anyone know if the V8 linkage from a 76 dart swinger with console shift is EXACTLY the same as the linkage from a 67 /6 console shift?
I had a problem with my gear selector being off and it was a ratio problem. The arm on the trans for the gear selector had to be changed. There are many different length arms.
thanks C Stanley - may i ask where you got your correct ratio arm?
thanks
- jason
........There r lots of diff arms.........can u throw up a pic of the arm and rod........u could may be drill a hole just inbord , that will change ur ratio, u should have a straight arm on ur 727..............kim..............
