old carb/new carb settings
green67cuda
Alabama
ok...got the old carb opened up...the old 600 vac sec has 65 jets (came with 64) and a 65 PV...the secondary plate is a 39, which is like 70 jets, the black secondary spring, and .031 squirter.
the new 770 cfm came with 72 primary and 75 secondary jets, a 65 power valve, the silver spring installed, and a .025 squirter.
i know the best results will come with tuning, but are there any obvious changes that need to be made to the new carb, considering the settings of the old one?
The secondary spring is an easy one to figure out. If you have a kick in the pants feel when the secondaries open then the spring is to soft. There should not be any noticable transition to the secondaries. If you don't have a kick now keep going softr to you do then go back one.
