One elusive fender tag code number
mayhem
Pacific NW
Hello friends, I've decoded this tag except for the HT5 in the first position of the middle line. Any help would be greatly appreciated. Thanks.
You can either clean it up a bit or take it off and look at the back side
HT6 is exterior paint code.
And it means body color for the lower code, and roof color for upper code.
Yes, thanks for the reply. Car is Doeskin Metallic (Dodge's name) top and bottom with a black bench seat interior. The 318 & 3-spd trans are gone but the car still has the pedals and column shifting mechanism. 741 open 8 3/4 rear end, small bolt pattern, drums all around. I'm building a 340 & on the fence about putting a manual trans back in.
