I live in Bloomington, IL
Got the grill in.
Took the grills apart, took out some dents, repainted and pop riveted back together. Got them shinier using a couple of compounds whose name I don't recall. pulling stuff off the engine. Going to replace water pump, gas pump, and exhaust manifold. My old exhaust came off in multiple pieces. In the process of replacing widow fuzzies and all the rubber seals. Irritated that I have to pull window assembly to replace wind wing rubber. But it will give me the opportunity to clean and lube everything. Every day is an adventure.
