Oops...changed the cam
edbux
Caldwell, Idaho
I had a smart idea and changed the cam. Went from an Edelbrock Performer cam the previous owner had installed to Comp Cams 270H-10. Rest of the 360 consists of 8.5 compression, LD-340, Mopar performance ignition with orange box (soon upgrading to FBO system), Rhodes lifters, stock 360 heads and a holley 1850 in a 67 Dart with a stock convertor and 727. I'll be getting a 2400 stall installed as soon as the concrete floor in the garage warms up a little.
With the old cam, I could smoke the tires easily and for a long time, 3.23 open rear, have 3.23 sure grip pumpking waiting to be put in. I installed the comp cam on a 106 center line per the instructions. I know my compression is a bit below the recomended minimum, but I am planning to eventually swap over to magnum heads.
Anyways, the problem is a severe hesitation on a wide open launch, runs fine part throttle to full. I bumped the discharge nozzles from .031 to .035 and not much help. Vacuum readings are 15 at idle in neutral, 11 in gear and it drops down to around 3 when I nail the throttle when launching (many odd looks cause of the long black hose across the hood). Advancing the initial timing helps very little. I know my jetting is somewhat lean from reading the plugs. I plan on ordering a jet kit. What I am trying to understand is the power valve. All that I have read say use on that is rated 2hg below your idle vacuum in drive. Currently it has a 6.5, if I understand it correctly I should be using an 8.5? Is the vacuum dropping to 3hg indicative of another problem? Also, at the timed port, I get around 2.5hg at idle, should I get anything there?
Sorry for the long winded post. Here in Idaho, no one knows of a Holley guru and it's mail order for parts. I'd like to get everything I need in one trip to summit's home page.
Thanks
The power valve is ok to use. Your bog is caused by a lean condition. It either needs more pump shot or the secondaries are opening too soon. Did the carb sit for a long time dry? Could the power valve have dried up? Any spark knock problems? If its not knocking maybe it wants more timing. Maybe try a stiffer spring in the secondary diaphragm.
I would try bumping the base timing up a few degrees. That cam would probably like 14-16 degrees at idle at 36 total. The higher stall converter should also help.
I agree, I would defiantly try a little stiffer spring in the secondary's. If vacume is lower than before the cam swap. which is what I would expect you could drop the power valve a little also. But like Adam said a little more converter is s in order, but that probably isn't your maiin problem. Just do one thing a time until you resolve the problem.
Thanks for all the info. Changed the jets from 62 to 64 and the power valve from 6.5 to 8.5. The Dart runs great now, can't wait to get the new convertor in. Also going to order the FBO ignition this week.
