oops low test in my Challenger R/T
Mopar General Discussions
  1. Gib Warnick
    Gib Warnick '65 Valiant signet FABO Gold Member
    1,209
    235
    Jun 6, 2006
    Mt Airy, MD
    Local Time:
    10:10 PM
    I filled up my 2012 Challenger R/T the other day and realized I had filled it with 87 octane gas. I had about a 1/4 tank of 93 octane. Should I get some octane booster or just drive carefully and take a long cruise and refill when gets to 3/4 tank. Manual says 89 OK but 93 preferred. What do you recommend? Thanks
  2. Marcohotrod
    Marcohotrod Well-Known Member
    2,422
    635
    Mar 21, 2015
    Massachusetts
    Local Time:
    10:10 PM
    drive easy, good that it is not hot summertime. add some 93 when u can. 89 ok. it has a computer-nothing to worry
  3. Gib Warnick
    1,209
    235
    Jun 6, 2006
    Mt Airy, MD
    Local Time:
    10:10 PM
    Thanks. I put in 87 like I normally do my daily driver. Don't drive Challenger much
  4. abodyjoe
    abodyjoe Well-Known Member
    22,194
    8936
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    10:10 PM
    drive as usual. the computer will adjust to the crappy gas.
    • Agree Agree x 4
    • Gib Warnick
      1,209
      235
      Jun 6, 2006
      Mt Airy, MD
      Local Time:
      10:10 PM
      Thanks guys. Computer knows best right. Stay safe and healthy
    • MRGTX
      MRGTX Well-Known Member
      1,981
      777
      Sep 24, 2007
      CT, USA
      Local Time:
      9:10 PM
      How empty was the tank when you filled up on the low octane? If you had some 93 still in there, you could be close to 89 anyway.
      I agree that the computer will pull timing and it will probably be ok but these motors don't tolerate overheating so add 93 as soon as you have some room in the tank and continue to drive gently. If you hear any ping at all, back off.
      • Like Like x 1
      • Tinmannz
        Tinmannz Well-Known Member
        308
        353
        Jul 29, 2019
        ‘Anytime Baby’
        Local Time:
        8:10 PM
        IMG_0557.PNG Add some of this. Go to their website and they have a blend chart in pdf format.
        Or locate a small FBO airport and buy some 100LL Avgas.
      • reddog
        reddog Well-Known Member
        117
        100
        Jul 30, 2009
        Davisburg, Alberta
        Local Time:
        8:10 PM
        I would say no problem, blend it up when you are able. Manual says 89. You had 1/4 tank of 93 so you are sitting at 88.5 with the 87 added
        At least you didn't put diesel in
        • Agree Agree x 2
        • Like Like x 1
        • LS-300
          LS-300 Well-Known Member
          654
          105
          Nov 19, 2008
          Ohio
          Local Time:
          10:10 PM
          With the new computers that control all the engine functions you will be fine. You won't hear any ping as the sensor will detect it long before you will notice it and make the necessary adjustment. Won't hurt a thing with only 1 partial filling.
          • Agree Agree x 4
          • MOPAROFFICIAL
            MOPAROFFICIAL FABO Gold Member FABO Gold Member
            10,115
            9457
            Jun 1, 2016
            Oceanside ca.
            Local Time:
            7:10 PM
            Stp octane boost.
            Entire bottle. No worries.
          • Hellrats
            Hellrats Just another dumbass
            1,591
            1333
            Jan 24, 2012
            N.E. Ohio
            Local Time:
            10:10 PM
            Just drive it. It will be fine. Be careful with octane boosters. Some don't play well with O2 sensors and catalytic converters.
            • Agree Agree x 4
            • Gib Warnick
              1,209
              235
              Jun 6, 2006
              Mt Airy, MD
              Local Time:
              10:10 PM
              Thanks to all for advice. I guess I'll drive gently when gets to 3/4 fill with 93 gas.
              • Like Like x 1
              • MRGTX
                1,981
                777
                Sep 24, 2007
                CT, USA
                Local Time:
                9:10 PM
                They don't play well with paint either...with some modern cars, it can be difficult (impossible) to get the contents from a bottle into the tank without a special funnel.
              • Gib Warnick
                1,209
                235
                Jun 6, 2006
                Mt Airy, MD
                Local Time:
                10:10 PM
                I took a cruise yesterday for 65 miles driving gently. Unfortunately the car averaged almost 25 mpg so I only got 2.5 gallons With the 1/4 tank I had when I filled it I think it's OK.
              • sireland67
                sireland67 FABO Gold Member FABO Gold Member
                9,780
                4194
                Oct 27, 2010
                WV
                Local Time:
                10:10 PM
                It will be fine, I accidentally put 87 octane in my 2012 Challenger R/T one time, I just ran it, no issues.
              • lilfontleroy
                lilfontleroy annoyinglilLeroy
                4,340
                3632
                Nov 20, 2017
                Intercourse
                Local Time:
                9:10 PM
                the factory suggests the higher octane fuel to keep the car at it's highest HP level, the only harm you have done is reducing your available HP for a tank full
