Valiant273
Active Member
Hi Guys,
65 Valiant 273 engine, electronic ignition
Had an issue with ballast blowing a few days ago. Replaced it and no change, noticed crack on top of coil and thought aha that's it. Nope, replaced coil no change. Next changed the ICM and that fixed it.
The odd thing is all of a sudden it seems to be charging way too high. My voltmeter, if correct shows almost 19 Volts under moderate throttle and about 16 on idle. Does not look good to me.
Even the original gauge in car shows needle way higher off just above middle then it ever was.
Thoughts?
Thoughts?
