Thanks...That is just the rubber gasket around the lens.......Perhaps I'll try a pressure washer? We can't get paint to stick on trim when we want it to LOL.OUCH! I'm not sure but the bezel around the lens should come off and then try to clean off the paint and if you're lucky and they didn't sand before they painted it the paint might peel off and then try to buff it out and you could try using a fine sandpaper then buff it out.
Correct.....And I think the silver is paint as well. IIRC, it is black everywhere the light doesn't shine through.That blue paint is what you want to remove?
