moparstilldeath
Active Member
Hey folks
I'm trying to remove my overcenter spring due to pedal not returning to the released position. I know this is the problem due to already having the thru firewall clutch rod disconnected from the pedal. I think the bushing is in need of lube or replacement. Any tips would be appreciated.
P.S. I have tried the washer stack up and still can't get it loose enough to pry it off. Pedals are still in car(66 cuda)
