This problem is likely made worse by the added fan IF you have stock wiring. Look up this article which slantsixdan LOVES TO CRITICIZE but I post it BECAUSE it points out the why and how of the base problem. Then rather than doing what they did, repair the bulkhead terminals because you STILL NEED THEM to feed the interior, and then make up a large gauge jumper cable direct --with a fuse-- from the alternator output to the battery.
HOW THIS PROBLEM (usually) works.
Look at the diagram in the article. ALL of the terminal points in the diagram can cause voltage drop between the battery, alternator, and back to the "run" circuit in the engine bay. The path is battery--fuse link--bulkhead connector (big RED) to ammeter--out on big BLACK--welded splice--back through the bulkhead connector and to the alternator
The DROP to the VR starts at the same place, and after the welded splice goes to ignition switch connector-- through the switch -- back out the switch connector on BLUE "run" wire--out the bulkhead connector --and into the engine bay where it branches off, feeding the ignition system, the VR, the alternator field on 70/ later, electric choke if used, and smog doo dads on later cars.
THIS DROP causes the VR to "think" the battery is low, and ramps up the alternator until the blue "under the hood" meets 14V. BUT THE BATTERY IS ON the other end of the voltage drop so it sees 15V or so, whatever the amount of the drop
HOW TO CHECK
With key in "run" but engine stopped, stab one probe of your meter into the top of the POS battery post. Stick the other probe as close as you can get to the VR IGN terminal. On 69/ earlier, this would be the IGN terminal at the VR. On 70 later, the "key" side of the ballast resistor.
Whatever you measure there, let's say 1.5V, is ADDED to the VR set point. So if the VR is properly at 14, then the battery is gonna see 15.5
CHECK THE GROUND PATH
The ground, too can have voltage drop. Run the engine at fast idle, with engine warm (The VR is voltage vs heat sensitive)
Stab one probe into the battery NEG post and the other hard into the VR mounting flange. The less you read the better, zero is perfect. here again, ANY voltage you measure will be ADDED to the VR setpoint at the battery. Improve grounding.
