Budgetmoparman
A little background about the vehicle. It is an 86 dodge truck that the previous owner had all cobbled together. I have converted to a 1 wire HEI distributor, eliminating the balast resistor. I just installed a brand new ignition switch (old one fried because of shitty wiring from previous owner). New alternator. New voltage regulator. I replaced a few of the wires thru the bulkhead when I put the ignition switch in. Battery has been tested and is good. Ohm reading from ground to VR housing is 0. Battery voltage is 12.47 engine not running. Voltage from battery to VR plug is 12.40 without engine running. Ohms for both field wires from alt to VR is 0. Some reason it is still charging at 14.95v. What else can I check? Did I check something wrong?
