69signetv8
First time involved with MSD!
My son is sending me a MSD 6AL. I have read the on-line installation and seen their so-called Chrysler directions, however I find when talking "MOPAR" specific..there seems to be something lacking or I just can't see it (mostly to do with the bal resistor, volt reg and ECU.)
Right now I have the upgraded electronic ign, 2-pin bal resistor, voltage reg and org box! I don't mean to be nieve, but with this MSD I take it the bal resistor and org box are no longer required?
Any of you have their "own" made-up electrical wiring diagram from the firewall out on the 6AL. I'm much better at following direct wiring then those "common" to all with some differances depending drawings! :sad1:
My e-mail is rjohnstonret@shaw.ca if you don't mind sharing your set-up
Thanks again!
Thanks again!
