P.S. fitting leaking at pump
gtxdude
Bloomington, MN
My hose going into pump has been sweating fluid out around the fitting, not real bad, just annoying. My question, is it the fitting and I need a new hose or can I put teflon tape around threads and stop it? One of those winter projects to clean up leaks. :icon_fU:
Are you sure it’s the tubing nut to fitting?
I’ve had the fitting (large nut) leak between that and the housing- copper washer goes bad or crack in sheet metal housing.
Look at the metal flare on the hose (not the nut) for cracks or a poor flare job.
The flare would be my first guess, check to see if it's split. or flared off center.
