[WANTED] P.S pump bracket
Shmaako
Winnipeg, Manitoba, Canada
Rating - 0%
0   0   0
I am in search of a powers steering pump bracket for my 383 big block. I just bought this GM Saginaw pump for my new Borgeson Box from summit without a bracket unfortunately.
I should have the brackets. There is 2 sizes to match the years of the water pump housings. Driver side lower hose has the wider bracket. Pass side is 1973 and up. Also some Saginaw pumps will not fit the Mopar brackets. Kim
