[Found!] P/S Pump/Brackets 69 340 LA Engine
CL3406
BC
Looking for a P/S pump complete with front & rear brackets, hardware & pressure hose if possible. Good condition with no dents is what I am looking. The attached picture is exactly what I'm looking for..This picture is off of unmolested 69 cuda 340. Thank you.
I have 68 pump with front bracket. Came off a 68 Fury with a stick 318. Not sure if I have the rear bracket but will check. If I don't have the rear and you still want it, I would ship it to you for $30.00
Thanks take a look and see if you can find the rear bracket. Attach a picture of what you have so I can make sure it is the same as my picture. Thank you.
I will but I'm sure shipping over the border will be high. PM me your address,thanks
I have one off a 71 340 also have others some with brackets some without
Thanks for your message...The 71 mounting will be different because of the newer style water pump (70 & newer). Sedanman is getting some shipping costs for me so I will probably take his. If not I will contact you to see if you have the correct one kicking around. Thanks again.
