chris_stevenson
well my question is has anyone ever had this wire harness kit go out on them? a while back my car was stalling out. I couldnt figure out why. then I had someone turn the car over for me and the yellow ground wire was arcing off one of my spark plug wires. so I moved the wires taped them away from everything few weeks later. the car started randomly stalling now nothing. no transfer of power from the coil on the + side. I unpluged the + and used a meter. no power but I checked the main power source and thats good. ballast is good. checked distrubter and thats good. ran a ground wire from the coil and theres power going through. so my guess is somewhere in my harness its no longer grounding. the yellow wire shorted out or burned inside somewhere. I ordered a new wire harness. 23 dollars isnt much to fix this problem but just was throwing it out there to see if anyone has had problems?
