p7 ebay heads
What block will you be running? I believe these fit the R5 block only. Don't quote me on that though.
They don't crack, no. They also have berylium seats - only a speacialized shop has the tooling and equiment to cut them (it's poisonous to machine - you need a respirator setup...)
I thought they looked pretty wild with the staggered intake and exhaust rocker setup.
Wanted to see what their track record is like, and they're not THAT much more than a prepped set of Eddies
Thanks for the input guys,
I was thinking of these for a 273, but after looking at that link, a head that flows 414 cfm should be good for... I dunnoh.... 18000rpm on a 273
I know it doesn't fit now
Might as well get the aluminum block to go with it :D
SeeBee did a top end/cam job,on his 273 Cuda.Check the search feature,way cool thread.Mild ported heads,nice cam combo.If you can't find it,PM Wildncrazy guy.
