Painless wiring kit
Slappy
Tampa Fla.
Anyone ever use this kit? Considering buying one for my Demon and would like some advise.
Yes, I have used the painless 10127 kit in My 71 Scamp. It not just for one car. The same kit is used on other year Mopars. If you plan on using your steering colunm and dash, I would make sure you have a good wire diagram. Some of the wires in the kit are not the same color as the ones in your car. They are labeled ok, but you still need the wire diagrahm to make sure that wire goes to what you want. You will need a test light and 12v power to test lights and ignition. It not as easy as Painless wire says. You will have to take your time.
"Which one?" Painless sells several
10127 any other companies out there that do wiring kits? Im going with aftermarket gauges
Many. American Auto wire. Rusty is going with a more generic kit...........and the name eludes me at the moment............
I've used EZ Wire Harness and I was pleased with it. Took a few phone calls to there tech guy Sean, but man he knows right away what needs to be done if your stumped.
I used this kit with aftermarket gages. Already had my own wire harness set up for my gages when the original stock harness went bad.
