Paint Recommendations?
rivertaff
California
I have a 67' dart with its original 88 bright blue metallic or bright blue poly, does anyone know where I can buy this paint by the can?
I did find a ppg code for it wich is PPG: 13336
You mean rattle can?
Some paint suppliers can make it up for you
Just keep something in mind: If you're going to try to panel match or spot blend an area, you may be better off having the paint shop scan & color match your existing paint- chances are the PPG code may not match well with original paint that's been exposed to 53 years of California sun... just sayin'.
Good paint supplier can make you a small sample that you can compare to the inside of the trunk for color correctness.
If your not going for 100% OEM the color code PPG has would probably be close enough.
my auto parts has had dupont/axalta since 1972
i started working there in 1978
i bought the store in 1986
i have the 67 paint chips and info
pm me
