My*65*Dart
When you paint your engine Does the engine paint go right on the bare metal or is there some type of high heat primer? What has worked for you?
i use one coat of duplicolor high heat white primer under 2 coats of chrysler engine orange. has always worked great for me. the key is clean, clean , clean
Did you paint after assembly or before?
