I need some help on the the parallel 2bbl conversion is setup. If anybody had pictures it would really help. I can't figure out how to get the throttle cable to fit properly. All help appreciated.
Here are some picks of my super six conversion. I used the cable and pedal assy off my 76 Aspen. Built a plate for where the shaft went through the firewall. Don't know if this will help or not.
I was searching and I think I got the wrong terms on here. It is an intake that has a parallel opening to the engine block. The linkage will be perpendicular.
Keep in mind that the car used for the article does not use cable linkage, it has a throttle rod if you are using a cable you don't have to do the carb mods you just need the appropiate length throttle cable and kickdown cable setup.
here another one. Make sure to click the one red link on "61 v200"'s post it is right beneath his picture of a 61 plymouth. The link title is super six conversion stromberg.
