[Found!] Parking brake return spring for 10” drums
75slant6
Russellville, ky
I’m looking for a single parking brake return spring for 10” drum brakes. I’ve attached a pic of the spring I need.
Thanks, Caleb
The 9" drum parking brake strut spring is different.
The 10" and 11" drum parking brake strut springs were the same part
and had part number 2533822
those are avail at napa, if you find an old guy to help you. might get lucky and find 1-2 younger fellas to help you
Yeah I tried a spring from a 9” brake but it wouldn’t fit over the bar.
I got a set of these springs from my local NAPA. If you need the part number let me know, I think I still have the box they came in.
That spring on the cross bar should have the tab to the outside or drum side not towards the axle tube.
I agree the return spring is on the cable. Also the spring at the parking brake handle. All three work together.
I found the box from NAPA, the springs come in a set of two and were pretty cheap - like a couple of bucks. The part number is 80744.
