dart gt
I have a 74 Duster that started howling when under load and quite when you let off the gas.Took center section out to check it and found out i had moser axles in the 8 3/4.Now i need to find out if these are the green bearings i hear are no good.There are 355 gears with a shir grip.Any help is greatly appreciated.Thank You David
