part number for an
rbkt65
jerseyville, illinois.
11x2 1/2 smooth brake drum with 4 1/2 bolt circle. i googled a few but can not confirm what app is. tia. rick w.
I may be wrong but I don't think Mopar ever made a large pattern drum, they changed to disk brakes with the pattern change.
Think you are measuring outside diameter on the brake drum.
2 1/2" x 10" are a standard size.
Try that and search again. Look under B body cars.
Have a look. ^^^
i am building a dana for an a body. making it std width. going to use 11x 2 1/2 inch brakes. i would like to use the smooth drums instead of the finned drums if they make them. yes it will be 5x4 1/2 inch bolt pattern.
You'll probably have to find some good used drums. I believe all the replacement ones are finned. Finned ones are a better design anyway as they cool faster.
