glhx
ive got the 68 engine front end sitting on my 76 timing chain cover.
Power steering bracket, alternator bracket, water pump, and pulley set is all 1968.
Engine is 76
I would like to convert it back over to the later stuff 70+ And run a denso alternator.
My radiator is passenger side pick up already so I have a adapter to make it drivers side (custom made tube) I want to run a passenger pick up water pump with the original hose.
I want the non a/c pulleys and the correct brackets for the 70+
Any pictures.....part numbers......will help
Which factory pulleys should I use. I don't believe any of the 68 pulleys will work.
Engine is 76
