parts change
TPTJ40
Member
Will the front suspension/ brake setup from a 75-76 valiant work on a 68 Barracuda? Are there any major trouble spots to look out for?
Thanks
what parts do you have or plan on getting?
my 73 duster disks fit on my 66 vally.
i used the upper arms and lower balljoints and everything in between and the portioning valve and it went right in and it only took me half and hour..
i would think that all the parts would be the same mind you i havent owned a barracuda before.
yes, they will. just not the sway bars, they go thru the k frame unlike the 72 and earlier. if you have a sway bar, just mount the spindles on opposite sides to move the calipers to the rear. the spindles are symmetrical. then get 77? or 78? aspen hoses and cut the bracket off. I upgraded my 68 cuda to the cordoba 11.75 rotors.
