Passenger front turn signal not working. 68 Dart.
KevenP
Member
Vancouver,WA
Hey all.
The parking light works and the other 3 turn signals work.
Any thoughts?
Thanks!
Remove bulb, check for power, and check the bulb, for a start
What have you actually done?
If the bulb is good and you don't have power check the correct wire coming out of the TS switch connector
Does the dash indicator lamp function for both left and right?
You can download free shop manuals and wiring diagrams at MyMopar
http://www.mymopar.com/index.php?pid=31
Then it's most likely a poor connection at the socket, or where the wire feeds through the bulkhead connector
Found it! Loose wire at the firewall bulkhead.
Now I need to figure out why the interior light doesn't shut off. :)
Thanks! :hello2:
The yellow wire feeds to all door switches, and also to the headlight switch. Make sure it's twisted "to the right"
Thanks! :hello2:
The dome light is has 12V + all the time. the yellow wires go to ground. So light circuit completes by completing the ground side of the circuit.
Thanks.
I've got to change out the headlight switch anyhow. Hopefully I find another loose/bad connection. :)
