How often should you replace the PCV valve? Is it still good as long as it rattles when you shake it?
Fred B
Fred B
I don't run one on my 340....should I?
PCV, easy free ventilation, keeps sludge down. Doesn't do jack to performance as its closed during WOT and low vacuum situations.
I spray gumout in mine while the engine is running to keep it and the hose clean and unclogged.
pcv, easy free ventilation, keeps sludge down. Doesn't do jack to performance as its closed during wot and low vacuum situations.
Oh boy! Here's where the thread takes a turn? LOL:happy1:Wouldn't it be great if they made PCV valves out of PVC plastic....
Then you could have a PVC PCV.....
Yes, valve covers always leaking.....and blow by from the breathers when I hammer on it...thanks, I will install one when I get it out in spring, I have the correct chrome one for my 66 273 commando covers....
Fred B
..............Not necessarily......if u can blow back thru it, its time for a new 1.............kim............
