Peak dash question
dartboy73
So my dash has been out of the car for over a year and I went to put in my rocky Mountain dash cluster and it does not seem to fit at all. Did anybody else have issues with these clusters? I'm just wondering if my dash actually warped from sitting so long out of the car
What did you have to do to make it fit? I made the mistake of painting the dash before fitting the cluster so the less I have to scratch it the better
Did you already clearance/cut the needed areas in the car to make the dash drop in? I had to take some parent material off the dash frame before mine fell into place.
I'll see if I can find the pics I took when I installed mine...
I had to cut quite a bit of the original dash out to get the full dash to fit. I then spent hours and hours working on the glovebox door to make it fit. I'm still thinking about taking another 1/8" off the bottom so it doesn't hit the main dash after it's painted.
Riddler
