Thank you for the replies. The weld on the L bracket did look a lot better than the ones on the extension/pedal stop.
Since those were taken with the clutch pedal in the down position, here is one in the returned position. This is why I didn't know if it was supposed to be a up stop, or a down stop, or both.
This assembly came out of a 69 340 swinger.
On your picture of the factory pedal, what is the small spring looking thing? My pedal does not have that.
