Peg leg thrust block removal
Kernel Sanders
eating chicken wings and drinking beer
Ottawa, Ontario, Canada
Hi
I'm changing to green bearings on my 8.75 and need to remove the thrust block from the carrier. I have never done this before so I'm wondering how to remove the spider gears... more accurately how to remove the peg that the spider gears are on so that I can remove the thrust block.
Is the peg threaded into the carrier as one end has a slot as though a large screwdriver is needed and if so right or left hand thread? Or perhaps it is pressed in in which case I do have a press to do this easilly.
Thank you and hope everyones having a great weekend!
that peg is called the cross pin. there is a retaining bolt on one side of it that threads into the carrier. Remove the bolt, pop the pin out, and the thrustblock should come right out.
