Hi,
I'm building a Sleeper 67 Dart 4dr.
What do You have available? 3.55 or 3.73 Ratio Gears - Starter - Headers - SB Rockers & Push Rods- Heads? Please let Me know Your Items & Prices......
Thanks Modog1967
Here's an updated list of what is left as of 10/14/13.
Sorry, Not a fire sale on the stuff that is left. If it doesn't sell...will use it up someday. Thanks.
FOR SALE:
NEW Speed-Pro R9278+.035". File fit, plasma moly ring set. 4.350" bore. 1/16 x 1/16 x 3/16 with low tension oil rings. $90. (summit @ $123)
New Moroso solid motor mounts for B,C & E bodies for all V8s except hemis. Part #62520. $25
MSD 8739 2-step module. Fits above box and others. $35.
Take-off 3.9 liter V-6 stock valve covers from 1991 - only 10K miles. $5
New Mopar Performance P4120459 1/2" head bolt washer kit. $10
2.74 first gear/low gear set for 904/999 torque-flite transmissions. Get off the line quicker. $100
New Elgin 383-400 3/8" moly pushrods for adjustable hydraulic lifters. Cup & Ball ends. 8.300" overall length. $75
Manton RB BB Mopar Pushrods 3/8" heavy wall. Cup & Ball ends for adjustable rockers. Set of 16. 8.710" 'Effective' length or 8.780" overall length. Low runs-like new. $100
NEW Manton series 4 heavy wall 8.900" x 3/8" pushrods. Ball/ball ends, hardened tube. Never used. Set of 17. $150 OBO $225 New.
SB Mopar Adjustable Pushrods for hydraulic lifter and stock type rocker - Ball ends. 15 good...1 Bad. $50
New TCI 5.0 ratio Band Apply Lever for 727 & 904 Torque-flite transmissions. $20
S.B. Mopar 273 factory connecting rods. Used in other small blocks for liter weight rods. $80 1967 440 Engine block D440 Dated 4-7-67 if someone needs a correct date coded block for a restoration. $500. Heads and intake also available.
Brand NEW 1996 Dodge Dakota truck frame. **BARE** For 2 wheel drive short box. Cut off at rear axle...have rear section(approx 3ft). You Haul! Want rack and pinion & A-arms on a street rod? $50
TRW Forged 340+.030" (4.070" bore) 12.5 compression domed pistons. Lightened and gas ported. 1/16" rings. Takes .990" BBC wrist pins (not included). SBM is .984" pins. BBC pins have more available wall thickness & lengths. (Almost $500 in lightening, gas porting and boring wrist pin holes. $100 or make an offer/trade.
