picture or diagram of a small block power steering pump set up
HemiEd
Tablerock Lake
I am putting PS back on my Barracuda.
I am looking of a picture, or sketch of the pump mounted on the motor, and can not find one in the service manual.
Does anyone have a close up of theirs, or a picture you could post for me?
Thanks in advance!
Nobody has a picture of their PS pump mounted on their engine? Please?
The first 2 are of the pwr steeering on my daughters 273 66 cua, and the second 2 are from my 73 340 duster.
You're most welcome! I started taking pics of everything I disassemble, for that same reason. Sometimes, without pics, it is not so obvious how it all goes back together, so i feel you pain.
If you need more, I can send you some this weekend.
Oh, and FWIW, don;t forget to put sealant on the long bolt that passes through the water pump, since it penetrates the coolant jacket, and may leak otherwise.
I think I get it now, just need a dual water pump pulley, and I will be all set. I bought seal kits for the pump and sector from Steer and Gear, so it should be a nice setup.
Thanks for the heads up on the sealant, I learned the water pump bolt lesson a long time ago, the hard way. :D
Have you ever left the long timing cover passenger side bolt out, below the water pump, overlooking it? When I went back to small blocks a few years ago, I did that. Wow, can coolant run out of there fast!](*,)
Your motor looks great!
