50-60* with the vacuum advance "all in" is perfectly normal
As others have said, play with your timing WITHOUT the vacuum hooked up. All it does is at LIGHT throttle, when intake manifold vacuum is HIGH it advances the timing "more" and gives you better mileage.
But for "power" IE lots of or full throttle, acceleration, the initial + mechanical is what you want
Mechanical is just what it implies ---centrifugal weights in the distributor try to fly out at greater RPM, moving the advance mechanism. This is controlled by SPRINGS which weak, weaker, stronger, etc, control "how fast" this happens
The length of the slot in the mechanical mechanism determines how many degrees the mechanical / centrifugal advances, while the springs control at what RPM
Try not to get confuses, as "the books" usually describe the mechanical and vacuum advance specs in "distributor degrees" which is 1/2 "crank degrees." That means if you have a distributor with 15* "distributor degrees" that is a WHOPPING 30 at the crank--and that would be a stock/ "smog" advance.
Many distributors have the advance no. stamped on the mechanism. This is DISTRIBUTOR degrees.....................
weights and the slots. Springs have been removed............
Stamped on the bottom, this 15* is 30 at the crank, "a lot"
FBO sells an advance plate which allows you to adjust factory distributors.................
Go way down to the left side of this page
http://4secondsflat.com/Ignition.html
and look for the
J685K Limiter Kit All Mopar Electronic Distributor
So the relationship is "all additive."
You set the timing with "initial" advance, what it is that you set at low speed idle. This is with vacuum UNhooked, and idle FOR SURE low enough that the centrifugal (mechanical) is NOT "kicking in."
The vacuum is whatever "is in the can."
So you set initial, at high engine RPM you add whatever mechanical is "in the distributor," and at high (enough) RPM that the mechanical is "all in" and you are cruising at light throttle, you add what the vacuum is doing. All three added.
