74360duster
JEREMY
i have just removed my rear slide a link bars off my duster,as well as the stock leaf springs.i took the super stock springs out of my cruiser and installed them into my drag duster.i am going to move the top of the rear shakle forward to move the rear bottom shakle straight back to give more drop in suspension when torque applied.my pinion angle right now is 0.i need 5-7 degrees down on angle.what size shim will accomplish this.does a 2* wedge change it only 2* or does it change it more at the pinion.this is my concern.do i need a 2 or 4 on the shim.any info would be greatly appreciated
thanks
thanks
