Pinning Intermediate Shaft?
Bodyperson
Pedal to the metal
NW MONTANA
Should it be pinned? Not too sure I have good enough equipment to do it myself.
What is that mark on the collar of the gear? You sure it is NOT pinned? I've never seen one that was not, but I've only seen, maybe, 20 or 30
I think its just a blemish. The one I am using for priming did not have a pin but it sure took a lot of effort to drive it off. Ill double check it.
Man, if they pinned it, they sure did a good job of disguising it. Ill try to contact the manufacturer. Not sure why I went with this company.
the lower part that's hexed, where it engages the oil pump drive, should have crisp edges. no wear or rounding out.
which if yours is new, should be just fine and dandy.
Yes, it is fine and dandy. I just checked all of the engagement with the cam and distributor and it is all good. It is a new shaft.
All the factory drives I have seen were NOT pinned. It is so easy to pin them for peace of mind that I would do it. Without the pin, you rely solely on how tight the interference fit is....& hope the person did a good job.
I'll just say this I've never built an engine from scratch that I didn't have a hardened/pinned Gear in... yet I've never had a stock V8 that ever spun the gear that i know of. Now I have built many engines and one of the 390 Ford FE Motors that I built received a high volume oil pump to which the stock oil pump Drive used twisted and snapped upon firing the engine. Deduce and choose. HV/HPSI pump =hardened shaft males sense to me.
To each their own.
It's hardened. I kinda sorta already had this disscusion in another thread. It fits well. Engages the distributor nicely. Very little lash.
I wouldn't install an UNpinned unit in my worst enemy's engine. Just too risky for me to think about. I got other worries.
Define/determine 'quality'. As I said in post #18, if the interference fit is tight enough, you are good. But how do you determine how tight that fit is when you buy a unit that has been assembled???
So, is the argument - since you don't know the interference fit, you must pin it?
How about this - Have you seen any intermediate gear slip on a shaft? If so, which one and under what conditions?
Not sure I've ever heard of it happening. I always thought the hex at the bottom was the weak point - even on unpinned units. Who knows?
No, never heard of one slipping. Does that mean it can never happen? No. Considering how easy it is to add the pin, it is a good safety measure. Don't forget many folks use thicker oil or stronger oil pump spring, both of which put more load on the drive.
