I'm pulling my motor 3 years after a rebuild to check it over and sort a few things.
When I built the motor I used Sealed Power cast pistons which give a comp ratio of around 8.6. I'm considering removing these pistons for the same make version that offers around 9.5+ compression.
Intention is to remove the ridge in the bore and slot the new pistons in.
The overall intention is to up compression amd allow for a 268 cam.
currently the Dart runs low 14's and is super reliable, i'd like the same but running mid 13's
2300 stall
3.23-3.91 rear 9undecided as yet)
What do you guys think?
2300 stall
