Pivot shaft bushing
Tarek Baratta
Delta BC
Sorry if this had been mentioned else where, I just did all my front suspension and noticed my new pivot shaft bushing did not need to be pressed onto the pivot shaft. To my understanding it's recommended to press it on first but once again, it just slides in and out freely. If it's ment to be a tighter fit does anyone know of a better product then the moog ones on rockauto, thanks
Standard OE metal sleeved rubber bushing?? They are a press fit both to the pin and into the lca. Lots of reports of moog making undersized crap.
it needs to be press fit.
proforged is good quality. i've had good luck with Delco Gold and mevotech supreme lines as well.
avoid moog lowers at all costs.
Thanks, ya I think I'm not buying any more moog parts, even the bump stops compared to the melvotech ones just seemed cheaper made and we're more expensive
