From a post I made on another forum...
I am using MSD Streetfire Wires on my project. They are a made in USA, 8mm, black. universal fit set. Cost about $35 at Summit.
Unfortunately I cut one wire a little short, and wanted to redo my coil wire with straight boots/terminals instead of the 90 degree ones that came with my kit.
Autozone was on the way home from work. I usually expect the cheapest of the worst from them, and was expecting to buy a single wire along with boots and terminals for the coil wire.
I ended up buying a complete set of Duralast #1601 cut-to-fit wires (90 degree dizzy & plug boots, straight coil wire boots, plain black rubber, 8mm, 2 year warranty) that are made in USA and look an awful lot like my MSD's. For $15 the set.
I was very pleasantly surprised at both the quality and price. Unless they turn out to have some hidden flaw these should be real popular with the budget-minded rodder.
FWIW Duralast #1600 is the same wire set but with straight plug boots, and both sets come with terminals for HEI & socket style dizzys.
