pishta
I know I'm right....
My 60 year old 3/4 gal main water feed split right under the house shutoff. I turned the water off at the street meter and dug out the pipe. That 3/4 galvanized pipe is about 3 inches in diameter because of all the rust on it and I cant even make out the 90 that it screws into at the bottom turn to the run across the lawn to the street. I cut the bad section out and patched it with a section of braided nylon tubing (150PSI rated) and some hose clamps. Its holding but its not permanent (or is it?) . Question. Do I attempt to unscrew the rest of the 10" of pipe that goes down the crusted over 90 or is that sure disaster, breaking the pipe at the threads of the hidden 90 causing more of the run to be replaced? I looked into the compression fitting, but I dont know of I can get the outside of the pipe ground down to the necessary round shape? Or will unscrewing it simpley break the corrosion and make it come out exposing fresh threads for the new 18" nipple? To make it even more fun, the foundation where the pipe runs down seemed to be carved out for the pipe so I have zero room for a bulky compression fitting right above the 90. Thanks.
