moparmat2000
hi all
had a new shop built in my back yard last year. it is 27' L x 31'W x 12' tall. i was originally working out of a hangar at my regional airport. i got friends is all i can say LOL. now that i got everything under one roof in my backyard, i want to plumb an air manifold for air hose connections from my air compressor and remotely mount the compressor behind the building.
at my work we used schedule 40 PVC pipe and it seems to work just fine, but i am not a big fan of pvc. i was thinking more along the lines of using sweat fit copper pipe with a short 3 foot piece of air compressor rubber hose to connect it to the compressor tank.
what kind of pressure can the copper pipe take. i know pvc is used as a replacement for copper in water applications, i also know it can get brittle in freezing temps. i plan on pressurizing the air manifold to 110 to 120 PSI and having 4 air hose quick connect fittings run off of it one in each corner of the shop. i think the sweat fit copper would look a lot nicer, plus i think its easier to work on than the pvc.
any thoughts?? anyone do this kind of thing i am wanting to attempt??
thanks
matt
thanks
matt
