While trying to avoid a pissing match.....
The first problem is the blurred line.
You don't exactly have a Holley on your ride. You have a aftermarket modified carb based on a Holley. The ThermoQuad has no such after market support. So since I can not have the same luxury you need to get a box stock era correct Holley that the manufacture used as OEM to compare.
When you get a Holley on your ride, let me know.
You have a modified unit from Quick Fuel.
There is also so many Holley carbs, which one? You always write and sometimes just write in caps, "HOLLEY!" With so many versions, you leave a lot to desire. OH! How much money for for your Quick Fuel? (New)
Now, if you wish to continue this convo, please by all means PM me and we can then continue. Until then.... I'm sure you can refrain from carrying on and turning the thread into a mucked up mess.
As per your challenge, I'd love to but would rather not waste my time & be around a negitive atmosphere where I get the feeling you would just be a loud mouth and yell things like "Imagine how much faster you would be with a Holley." And other such normal comments is bet you would make.
If you actually read my posts .......
