schwinger
1972 Dodge Dart Swinger
I have a 1998 5.2 magnum engine in my 72 dart with mild cam 490/490 lift 108 lobe separation, cant remember duration, speedmaster 4bbl intake and fitech, stock exhaust manifolds, stock rebuilt magnum heads that have been milled .010, blocks been milled but dont know how much was taken off and has flat top pistons. Driven the car for awhile with about 12000 miles on the motor and recently started smelling burning oil when i get on it so checked all spark plugs and found out #2 cylinder was fouled up with oil. looking into the cylinder with a flashlight it looked pretty oiled up so wondered if oil ring got messed up or piston cracked idk so Did a compression test and all cylinders were 150 except that one which was 180, higher than the others so wondering whats going on? Did take the valve cover off and checked the valve seals on that cylinder which looked to be pretty good and wasnt loose but did notice bottom of valve cover had a thick brown almost milkshake film to where i wonder now if the intake gasket is leaking or not.
